Question about LT1 heads and cam
Old Sep 25, 2005 | 03:50 PM
Leader_One's Avatar
Car: 1990 TA, 1995 Sierra 1500
Engine: 305tpi to LT1 mod, 305 TBI
Transmission: 4L60E with 3000 Stall, 5spd
Currently I have an iron head lt1 out of a roadmaster and I was wondering if I purchased the aluminum heads for it if I would get up to the 300 HP that the aluminum headed lt1's get or is there also a cam change between the 2? Which would be better to have when I build up the engine for performance as well? My plan is to rebuild the engine in a few years with forged internals, new cam, ported or new heads, and a twin turbo setup.
Old Sep 25, 2005 | 08:10 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The aluminum headed ones from the F-bodies like the one I have didn't make 300hp, I think they topped out at about 275-285. The iron heads you have have been said to flow better than the aluminum ones, but someone else may be able to chime in and say more about this.
Old Oct 23, 2005 | 09:32 AM
JDud's Avatar
The iron heads did flow better but if you go with a twin turbo, the aluminum heads will dissapate the heat better so you won't be as likely to get localized hot spots (causing pre-ignition/detonation). Just food for thought....
Old Oct 26, 2005 | 07:33 PM
TexasLT1's Avatar
Car: '92 RS
From my understanding the iron heads only flow better at lower lift values and about 5 cfm more in stock form at max lift. For a high performance engine though, you'd be better off going with the aluminum ones.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
