heater core/hose question...
Old Oct 18, 2005 | 09:48 PM
amc91z's Avatar
Car: 1991 Z28
Engine: 383
Transmission: TH350
did a search but couldnt find anything...i got rid of my heater core with my ls1 swap, what do i do about the nipples on the water pump for the hoses? Can i plug them, or do i need to find a U to loop it? Having a hard time finding a U to fit the two diff sized nipples. Any suggestions would be helpful!
Thanks,
Adam
Old Oct 18, 2005 | 10:21 PM
TexasLT1's Avatar
Car: '92 RS
I'd just cap them off.
Old Oct 19, 2005 | 06:10 PM
amc91z's Avatar
Car: 1991 Z28
Engine: 383
Transmission: TH350
i put caps on them, but the coolant isnt flowing....didnt know if it had to be looped together to flow or if i had another problem...
Old Oct 19, 2005 | 08:32 PM
TexasLT1's Avatar
Car: '92 RS
sure the thermostat was open?
Old Oct 19, 2005 | 08:52 PM
amc91z's Avatar
Car: 1991 Z28
Engine: 383
Transmission: TH350
i let the car idle for about 10-15 min and it got a little warm, then checked it, no circulation. The fans came on, but the radiator and hoses are not hot at all. any ideas? pull the stat out to see if it flows, if so, replace the stat? if not, then what???
Thanks,
Adam
Old Oct 20, 2005 | 06:13 PM
kevinc's Avatar
Car: 1982 Z28
You need to loop the two fittings so coolant will flow, others have reported problems w/ the thermostat not getting adequate coolant at the 'stat to open it when they've tried capping the fittings.
Old Oct 20, 2005 | 08:01 PM
TexasLT1's Avatar
Car: '92 RS
well there you go.
Galaxie500XL
Oct 1, 2015 01:05 PM
Formula8r89
Sep 22, 2015 04:24 PM
