height change with lt1
Old Mar 5, 2006 | 04:04 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
did any of your lt1 third gen cars height change with the swap? mine ringing in at about 9 inchs off the ground lol. if so. what did you do?
Old Mar 5, 2006 | 04:13 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
I went from an iron head 305 to an AL head LT1 and didnt notice any change. I'm sure there was some, but not enough to make a noticable difference
Old Mar 5, 2006 | 06:29 PM
Firebat's Avatar
what did you have in it before for an engine?
Old Mar 5, 2006 | 06:32 PM
xomega's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
late 70s 350. i rolled it out of the garage yesterday and noticed i had around 9 inchs of clearance infront of the drivers front wheel. from the ground to the bottom of the gfx. guess lowering it is a option. it just looks like its ready offroading i took some pictures. ill post it tomarrow
Old Mar 10, 2006 | 12:53 PM
TexasLT1's Avatar
Car: '92 RS
how much did you have before?
You did switch to aluminum heads and waterpump, thats going to take some weight off the front end.
Old Mar 10, 2006 | 12:58 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
Mine seems to be sitting and inch or so higher.
Old Mar 10, 2006 | 01:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I have about 8 inches from the ground to the bottom of the gfx and 3 inches from the top of the tire to the bottom of the fender. However, I only have 4 inches from the ground to the bottom of the air dam.
Old Mar 10, 2006 | 01:47 PM
ssean92's Avatar
Car: sold
Re: height change with lt1
i had the same issues, i went from a 305 with ac to lt1 and no ac and it loooked like crap. i ended up cutting the springs, till i can find a set of springs that will lower the car the way i want it with the lt1 in it. my car weights 3400 with out me, not sure on the weight before the swap
Old Mar 13, 2006 | 09:48 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
Your suspension should settle out after driving the car. Mine sat extremely high until I drove it and it settled out. I had no height change in my swap.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
midge54
Aug 29, 2015 09:51 PM
Thirim
Aug 9, 2015 06:19 PM
