some final LS1 swap questions
Old May 17, 2006 | 04:58 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
First what fuel fittings ect. do i need. Im running my stock fuel line (91 Camaro TBI) and im running a 2000 F-body LS1?
second what did everyone do with thier power steering line? or what will i need to do to my stock line to make it work?
Old May 17, 2006 | 10:56 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I was able to use the 4th gen power steering lines. I did not use the cooler.
Old May 18, 2006 | 12:20 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
You put a new in tank fuel pump in right? You should check fbodymotorsports.com. They have a fuel kit with all the fittings you need. Thats what I went with. We all also used the 4th stock power steering lines. They all worked fine, yet the hard part of the lines may need to be bent for clearance.
Old May 18, 2006 | 11:35 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Im using the 4th gen tank and pump, just the third gen line. And ill have to get ahold of some 4th gen power steering lines .
Old May 19, 2006 | 02:05 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Is this the power steering line a need?
Found it on advance auto parts site under 2000 camaro Power steering presure hose
Old May 19, 2006 | 11:47 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Yes, you need that 4th gen high pressure line. It also bends around the power steering pump properly.
Old May 23, 2006 | 10:03 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I'm also going this route, picking up the motor tomorrow, already have the tank. What hardware do I need to fit the tank to the line, then the motor to the line??
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Polo Z03
Sep 10, 2015 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
