Cooling hose layout
Old May 27, 2006 | 08:07 PM
dtsfanatic's Avatar
Car: 1987 Trans Am
Cooling hose layout
I used another tread on here to get all my hoses hooked up today. The only problem I ran into is that the upper radiator hose(tread said to use a 95 Z28 hose) will not work on my engine since it's a Vette and the branch off tube that goes to the back of the heads hits the A/C compressor. I have a hose for the 87 T/A but it doesn't have this branch off hose. What do I need to do with the t/b? Do I just cap them off along with the one on the back of the head on the passenger's side?
Old May 27, 2006 | 10:29 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I ran my hose like that for a while. I cut some off the radiator to make it a tighter fit. Then I put a zip tie around the two hoses to hold them together. It cleared my p/s pulley by about an inch. I recently switched to a 94 hose and did away with the extra hose to the throttle body. My steam vent now tees into my heater return at the radiator.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
