going to the track what do you predict
Old Jun 12, 2006 | 11:09 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
what do you guys think I could or will run?
CAR:
1987 firebird
ENGINE:
95LT1, LT4 hot cam, 1.6 roller rockers, 3 degree valve job, ported and polished heads and intake, electric water pump, adjustable fuel regulator, 52 mm throttle body, all emitions deleted, ac delete, descreened mass air, k&n cold air intake, pcm for less tune, 160 degree thermostate, crane multi spark ignition, msd 8.5 wires, 255 lph fuel pump
Tranny:
4L60E, custom built 3400 edge racing torque convertor, transgo shift kit, b&m tranny cooler
Rear end:
slp limited slip, 373 gears, mosser axels, rear end cover with bearing cap load bolts
Exhaust:
hooker long tube ceramic coated, mufflex y pipe, flowmaster 3" exhaust, 3" electric cut out by the rear end
Chassis:
8 point roll cage, strut tower brace, wonder bar, sub frame connectors
suspension:
1" hotchkis drop springs, hotchkis sway bars, hotchkis rear control arms, hotchkis panhard bar, control arm relocation brackets, edelbrock torque bar, kyb agx shocks and struts
Rims/Tires:
17" zo6 rims, 275/40/17 bfg kdw
Old Jul 10, 2006 | 10:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
howd ya do?
8.15-8.20 1/8 mile
12.50-12.60 1/4 mile
if i had to guess.
Old Jul 10, 2006 | 11:18 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Mid 8's I would say, especially if you weren't running drag radials or slicks.
Old Jul 10, 2006 | 11:23 PM
Car: 1987 firebird
Transmission: 4l60e
I have not had a chance to get there yet, I am still sorting out some bugs!
First I lost reverse gear, and I found out that the boost valve in the tranny fell into the pan, that was an easy fix but took a day. Now I finished up all my wiring for the electric cut out, line lock, and rev limiter and started my car up to make sure everything worked and I found out that the headlight switch was bad. It sould be at the track in the next week or so, I will let you now how I did.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
