Anyone running the LT1 hot cam?
Old Jul 4, 2006 | 06:22 AM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
I've allready bought a comp cams 224-230 on a 112 LSA but was curious as to how the Hot cam sounded and how much power it makes. Another Queston, what kind of headers are ya'll running on these LT1's? I've got a set of 1-3/4 hedman headers that came off of the 406, after looking though I don't think they'll work with these D port heads. I plan on buying a set of ceramic coated one's, hopefully mid lengths that will work with my hedman y-pipe.
Old Jul 4, 2006 | 12:59 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
1 3/4 headers will work with th D port heads. The tube is big enough to completely cover the LT1 port
Old Jul 6, 2006 | 08:17 AM
TexasLT1's Avatar
Car: '92 RS
I ran the Hotcam for 4 years. great street cam, made 320 at the wheels with a conservative tune and LT4 heads. had a great powerband as well. definitely a good street cam for a daily driver
Old Jul 6, 2006 | 08:38 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Only bad thing about the 1 3/4 is they aren't made for the angle plug heads. The Hedman 68479 (painted) or 66479 (coated) headers are D-port mid length that will work with the hedman y-pipe, and also made for angle plug heads. I have no problems at all changing the plugs out. Bad thing about those 1 3/4 headers, Hedman discontinued them for the 3rd gen f-bodies.
Old Jul 6, 2006 | 12:25 PM
98_LS1's Avatar
I didn't think about the angle plugs, crap, guess I'll go ahead and order the right headers and keep these in case I get another third gen. BTW, I ordered the fuel rail adapters from Performance Plumbing and plan on having steel braided fuel lines made at Royal Brass and Hose. Did you go with these? I'm using an Aeromotive Fuel pressure regulator, still need TPI fuel lines from the tank to the engine bay though
Old Jul 6, 2006 | 12:33 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I have 1 3/4 SLP shorties on mine and changing plugs are a pain. I use a cut off spark plug socket and a gear wrench. I have the hot cam in my car. I like it, but the springs that come in the kit are prone to binding if reved too high.
Old Jul 6, 2006 | 12:59 PM
Klortho's Avatar
Car: 1987 GTA
Nah, I made my own up using some FI rubber line from AutoZone. Royal Brass and Hose won't do Fuel lines, or at least they wouldn't last year when I called about having a set made up, so I made my own. I have a set of TPI lines, but one end was cut off in the engine bay so it doesn't have the screw on connector if you want them.
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
