TH350 & Wiring
Old Sep 22, 2006 | 11:08 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
TH350 & Wiring
Hey,
Working on getting parts for my LS1 swap and I have a freshly rebuilt TH350 sitting in an 81 firebird doing nothing.
How will the TH350 effect the swap as far as wiring and hookups for the shifter go?
Also, is it necessary to send off your PCM and Wiring harness to Hawks or Speartech to get it reworked?
Thanks,
Mike
Old Sep 23, 2006 | 06:22 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Im running a th-350 and the only thing is you have to use a 4l80 flywheel or a flywheel adapter from tci. There is no wiring unless you have a lockup th-350 that came in some gen 2 and gen 3 f-bodies and even with that it is just the lockup that needs to be wired
Old Sep 23, 2006 | 06:35 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Oh ok,
The tranny is in an 81 firebird with not even 50 miles on a fresh rebuild so seems only logical to use it since we are not using the firebird.
Mike
Old Oct 5, 2006 | 10:12 PM
jb's89's Avatar
I have an 02 6ltr out of a 3/4 ton which i believe has the 4l80. I held a tci 4000 for a th350 up to it and only one bolt hole worked, and it was a small one on the flat surface. Does anyone think i could mark and drill 2 more?
Old Oct 14, 2006 | 02:03 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
6 liter flywheel will work like a charm for a std small block style converter.
dont drill any holes, it will kill the balance, IMO.
shouldnt have a problem with it tho.
are there 2 sets(6 total) holes on your flywheel?
Old Oct 14, 2006 | 07:45 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Also make sure that the 350 Turbo is a multi bolt hole model and not just a B-O-P version which has a different bolt pattern than the Chevy/GMC ones.
Old Oct 15, 2006 | 01:58 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
for easy fitment, id look for a chevy only bellhousing. depending on a few things, you might have to grind some spots on a chevy/bop dual pattern for it to fit some exhausts and what not.
good tip tho. you DONT want a BOP only.
good luck!
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
