What hoses?
Old Feb 12, 2007 | 09:05 PM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
What hoses?
What hoses should I use to hook up the LS1 to the rad? Lower and upper.
Old Feb 14, 2007 | 08:12 PM
kevinc's Avatar
Car: 1982 Z28
Upper hose for an '02 Chevy Silverado 5.3L
Lower hose for an '01 Trans Am without PS cooler (1-piece hose)
Old Feb 15, 2007 | 05:53 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
Thanks alot!
Old Feb 18, 2007 | 09:27 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
I bought them and they didn't work. The top one is too long, and the bottom hose isn't big enough on both ends to fit on the rad and the water pump. Is the 4th gen rad outlets smaller than a 3rd gen? I am running a 3 rd gen rad. Did you mean for me to mod therse hoses?
Old Feb 18, 2007 | 09:52 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
YOu have to trim the hoses a little to make them fit. They go one alright but it takes lube and effort to get them on especially the lower one. Speaking of the lower one the one listed above doesn't fit worth a damn. Take it back and get the gates hose listed here
https://www.thirdgen.org/forums/engi...lower+rad+hose
Old Feb 18, 2007 | 10:23 PM
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
Here is the upper i used, no trimming, no lube. Gates # 20893
Old Feb 19, 2007 | 01:21 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
no lube
Ahhh come'on A little lube can make the best of any tight situation
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
