questions about 5.3 harness
Old Jul 9, 2007 | 02:11 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I got my motor set in and started wiring it up. I have a few questions about a few wires.
Blue connector by fusebox
-yellow/black pin E VSS Do I need this
Black connector by fusebox
-Brn/wht pin G check engine lamp does this just run to gnd on the engine light
-Grn/Wht pin D vss out do i need this
-PPL pin E brake pedal tcc does this just run to the brake pedal switch
-Tan/wht pin J oil pressure do i need this if I'm using my stock sending unit
where does ign switch connect on fuse box
starter wire from inside car? where to connect
TheJoeY88
Dec 31, 2016 07:30 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
