LS1 T/V Cable Solved
Old Aug 5, 2007 | 03:42 PM
Diabloformula's Avatar
Don't know if anyone know about this, but as I was seaching info for my future LS1/built 700R4 swap I found this.
http://www.bowtieoverdrives.com/cata...php?ITEMID=225
Old Aug 6, 2007 | 03:30 AM
Kingsize24's Avatar
Re: LS1 T/V Cable Solved
Thanks for the info!!!
Old Aug 17, 2007 | 11:45 AM
Just an update, I recieved my kickdown setup from bowtieoverdrives and noticed that this setup will not work for at least 2000-2002 LS1 throttle bodies, it seems the linkage where the throttle cable rides is shaped differant for the attachments that go there from the kit, I do know that the 98 model year throttle bodies will work fine, the 99's I'm not sure about. So in order for this kit to work with a LS1/700R4 you will need the 98 style throttle body or at least the linkage end off one to switch over.
Old Aug 17, 2007 | 02:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This was part of some info was supplied to me when I asked about differences between years of LS1's.
"1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT (wide open throttle) faster than 2000+ cars"
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
