TR230 dyno results
Old Oct 22, 2007 | 06:50 PM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
TR230 dyno results
I got my car dynoed again today after I replaced the bad plugs that I dyoned it with last time. The car feels a lot faster with the new plugs (old ones were fouled) so I thought I would see a good increase. The dynoed 2 rwhp more! I do not have the old graph sorry. The car still has the 2.73s with a t56. I am getting my 4.10s installed this weekend. We dynoed the car in 3rd, 4th, 2nd and 1st for giggles. It looks like the car picked more horse in 1st from 5200+ to 6k than the other gears! I wonder if the 2.73s and the t56 don't like each other on the dyno? I also have stock 98 that were port matched (bad job?) to a FAST intake. I currently have a LS6.
Last time we dynoed the car, my tuner said I was running out of fuel up top. I have stock injectors, unknown year.
The car doesn't seem to make any good power after 5200 rpm.
Here are my mods,
TR230/224
Ls6 intake
SLP underdrive pulley
Hawks Long tubes
3 inch mandrel bent, ORY, into a single Flowmaster 40 series
Tr6s
Msd wires
CAI
I think its the stock TPI thats killing the power up top. I am getting my Holley fuel pump tomorrow. Is the TPI pump dying past 5k?
Old Oct 25, 2007 | 05:51 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: TR230 dyno results
Pop a fuel pressure gauge on it and see what it reads.
Old Oct 26, 2007 | 09:04 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
The stock TPI fuel pump is sketchy on a stock LS1. With a healthy cam like yours its my guess thats your problem. I also recommend the hotwire mod for the fuel pump wiring. Pretty basic really. Use the PCM to trigger relay directly to the fuel pump rather than routed through the PCM so you dont get voltage drop at high RPM. Very common mod on the fourth gens
Old Oct 26, 2007 | 12:23 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
I just installed the Holley (Walbro) pump. Now I just need to get my rear end back and I can dyno it again.
Old Oct 27, 2007 | 08:10 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
those numbers seem really low for a cam setup. My bone stock 02 dynoed 331/342 with stock cam and headers/exhaust only
Old Oct 27, 2007 | 08:45 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
My old 346 setup had a TR230 in it with home ported heads, LS6 intake, pulley, hawks LT's, and a tune and it put down 399/380 on a set of slicks through a 9".
I definitely think your stock TPI pump is hurting you... I had a walbro 255.
My 402 now puts down over 600 on the bottle.
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
