Show me your engine bay
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Show me your engine bay
Here's some phase 1 pics of mine....
Last edited by 89transam*pearl; Apr 28, 2008 at 10:09 PM. Reason: Hit the reply button prematurely
Car: 1990 Camaro RS
Engine: L03 305 TBI
Sheesh, not one stock engine or TBI in here yet?
This is a daily driver. I can't afford to make it super fast, so I keep it clean as possible, so I have something to be proud of when I pop the hood...
The car has 110,000 miles on it, and was pretty well trashed when I got it. Interior and exterior. All together now I guess I have about $2000 in it. Thats $600 for the car, $150 for another donor car, and the rest in parts. Tires, starter, alternator, O2 sensor, EGR valve, plugs, wires, filters, brakes, audio, struts, drag link, ball joints, idler arm, tie rods, track bar, head liner, yadda yadda yadda, and a set Iroc rims with 245/50/16's on them. I'm sure there's more I've forgotten, but you get the point... As of now, everything works. Air, heat, cruise, wiper delay, all of it. Anyone wanna buy it?
Car: 1991 RS Vert
Transmission: 4l60e
Here is mine, I just got done spraying it on Sunday... Putting in a LS6 with a decent sized cam and a Stalled Auto, it's a 91 RS Vert. Color is Torch Red.
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
Here's my bay so far minus the 1LE heater box that show up on my doorstep tomorrow.
and from the other side
Car: 02 WS6, 83 WS6, and 78 Project
Engine: LS1, LG4, and 400
Transmission: 4L60E, T5, and TH400
Axle/Gears: 3.73, 3.73, and 2.73
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Thanks!
The bracket if from here: http://www.hotrodlane.cc/ They've changed the catalog, but you'll have to search under the LS1 accessory section. It's probably shown as part of a kit, but you can buy the A/C brackets seperately.
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'll toss some in. The cleanest TBI engine bay ever.
Car: Camaro RS
Engine: obd2 350 lt1
kubus i like your car alot... you take cool pics too but in the second one get a new coolant tank
Edit: mine is dirty too
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Car: '02 WS6 Conv M6, 92 WS6 Conv. M6
All the pictures look great! I'll post pics up later of the "current" setup and progress pics as I do a lot of custom work to dramatically clean up the engine bay.
One thing I see:
Nobody has figured out a way to get rid of that bulky, in the way, UGLY and HUGE wiper motor! (besides just deleting it).
Has anyone figured this one out??? I'm going to engineer a new system using a smaller motor and linkage/motor in the cowl rather than on the firewall.
One thing I see:
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Car: 1991 Chevy Camaro Z28
Engine: 5.7L TPIS Miniram
Axle/Gears: 3.73 Eaton Posi
I don't have a pic of the whole bay... I'll have to get one... once its cleaned and sprayed.
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
[quote=//<86TA>\\;3605470]I guess i get to post mine again, i need some newer pics...still need to deal with that fugly radiator hose
Nice bay
Why not go to your local parts store and look @ a catalog
You can, for sure, get one that shape without that restrictive ribbed junk
If you can't or don't have access, PM me, I'll try to find you one in my Gates Jobber Data Cat @ work
Nice bay
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
in the middle of my ls1/t56 swap but here are a couple of what the engine bay is going through
90firebird4.jpg?t=1269847787
grinddown.jpg?t=1269847867
RATTLE CAN WOOT!
cleanedbay.jpg?t=1269847908
RATTLE CAN WOOT!
doesnt the fitting on the water pump shoot downward slightly? i have the same fitting and water pump as you and becuase the way the tapping on the pump is, the 90 faces downward a little. but in your picture it look like it doesnt.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I made a template for the outline then took it to a friend who is a fabricator. He used a bead roller to put the lettering in. Then I polished it. I wish I had the equipment and talent to fabricate stuff like that.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Pic of mine from last night. Still needs to be cleaned but its almost done and ready for the rd. Havnt driven it in 4 years now
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Engine: 7.0L
lol, not very observant, eh? that motor is a 408 lsx based motor. and what does an ltx have to do with anything posted in the last 5 or so posts?
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Close to getting it on the road. Hopefully this weekend. Just need to do a couple finishing touches.
My coolant and squirt bottles are where my air filters used to be with the stock TPI setup so what you see here is my final. I tucked as much of the harness as I could underneath my upperplenum so you don't see them.
