LT1 swap and high revs
Old Feb 14, 2008 | 08:34 AM
Brothaman's Avatar
I finished my LT1 swap into my 1985 IROC, and it runs SWEET!! The only concern I have is when I first start the car, it will rev as high as 1800 rpm before settling down into a normal 800 rpm idle. The engine runs great overall. I think the computer does this to keep the car running initially, but should it rev this high? I have not seen any codes come up when I scan the computer. Is anyone else having this problem?
Old Feb 14, 2008 | 10:09 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: LT1 swap and high revs
I don't know the answer, but my 1999 Saturn SL that i owned for 5 years always did the same thing upon startup, particularly in cold weather. I'd like to know what caused it, but it never presented a problem the entire time I owned it.
Old Feb 14, 2008 | 10:20 AM
bhudson98's Avatar
I want to swap a 5.3L Vortec into a 78 Camaro Z28 that curently has a blown up 350 in it. What would this take????
Old Feb 14, 2008 | 11:08 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
This is normal to happen.
Old Feb 15, 2008 | 03:11 AM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
TPS sensor is adjusting it self, My 86 iroc does it it no worries just as long as it doesnt go to 2500 rpm. Typical Fuel Injection set up.
Old Feb 15, 2008 | 08:03 AM
TexasLT1's Avatar
Car: '92 RS
you can have the program adjusted to set the upper limit of the TPS sensor to keep it from running up that high.
Old Feb 19, 2008 | 12:42 AM
Brothaman's Avatar
Thank you all for your help!! I will just keep an eye on the RPMs to make sure they don't go too high!
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
