Just some quick questions about 93 LT1 swap..
Old Feb 17, 2008 | 09:31 PM
WhiteysTA's Avatar
Car: 87 Chevy Camaro Iroc-Z
Engine: 350 LT1
Axle/Gears: 3.27 9-Bolt w/TA Perf. Stud Gurdle
Ok, I got my 87 Iroc with the 93 LT1 already installed and have pulled all the wires from the C100 I need to swap it to the 93 LT1's harness. So far my only concerns have been with the vats module and the throttle cable. My first question is: What should I do about the 3rd gen throttle cable, the hole is way to small to connect it to the BBK throttle body on the LT1. Should I drill it out or machine the TB so it will fit on it? Next question: The car has the dash from a 92 Camaro installed in it, will the 92's VATS module work with the 93's wiring if I just connect the wires? Or will I need to get a new module and wire it into the 3rd gens harness? Also, how hard would it be to delete vats from the ecm if I cant make the one I got work?
Thanks to anyone who offers up any info!!
Old Feb 18, 2008 | 10:09 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Re: Just some quick questions about 93 LT1 swap..
Are you not selling it anymore?
Old Feb 18, 2008 | 03:05 PM
WhiteysTA's Avatar
Engine: 350 LT1
Yeah, i've decided to stick with the LT1 swap since i've already spent so much time getting the wiring sorted out. Plus to build that sbc the way I want to, i'd have to spend like 2 grand more then what I would get from selling the LT1. And the power will be somewhat similar.
Old Feb 20, 2008 | 03:07 PM
WhiteysTA's Avatar
Engine: 350 LT1
Anyone have any ideas about the questions I have??
Old Feb 20, 2008 | 03:44 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Its the same just plug it in. If not you'll know
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
