Optispark Failure?
Old Feb 18, 2008 | 07:49 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
Optispark Failure?
I recently finished my LT1 swap into my 84 Camaro. The car has about 3000 miles on the swap now (I picked it up from a low mileage junker car). Recently the car has no power above 3-3500rpm. If you stay in the throttle above that rpm range the car will start bucking and surging. Last night it threw a code and check engine light came on, but before I could get home (driving at 2000rpm) the check engine light had went out.
Is this the signs of a failing opti? (recently upgraded the stock coil to a msd blaster unit)
Will the PCM still recall the code even after the check engine light has went out?
Old Feb 18, 2008 | 10:27 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Optispark Failure?
Codes get stored in the computer, check the codes, then troubleshoot.
Old Feb 19, 2008 | 07:51 AM
tom camaro's Avatar
Car: 83 Camaro
DTC 55 Fuel Lean Monitor
Is the code I pulled. I have no clue what this means?
Old Feb 19, 2008 | 08:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
When the opti failed in my '97 after the water pump took a dump, it basically acted like half the spark plug wires were disconnected - no power, sounded rough, shook like a ****, and the SES light came on giving random misfire codes (mines OBD2). It acted like that at all rpm.
You should still be able to retreive the code, even if the light went out. Its supposed to be stored in the ECM's memory.
Old May 13, 2008 | 12:27 PM
tom camaro's Avatar
Car: 83 Camaro
Problem found and fixed.
It was not the optispark.
The gas tank was full of rust and the fuel strainer had clogged.
Old Jun 17, 2008 | 10:24 PM
gdubya038's Avatar
talk about a brian buster
gdubya038's Avatar
Grant2k
Apr 4, 2016 08:21 AM
Fanatic1074
Oct 2, 2015 03:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
L0tuS
Sep 4, 2015 11:16 PM
