LT1 won't stop when key goes to OFF
Old Mar 3, 2008 | 09:39 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Friend of mine has an LT1 and when he takes the key to OFF the car doesn't stop anymore. I asked him if he did any wiring....any minor insignificant wiring at all? He said no, so I'm wondering what might a cause? any pointers?
Old Mar 3, 2008 | 10:37 PM
Brian Esser's Avatar
Car: 1996 Chevrolet S10
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Re: LT1 won't stop when key goes to OFF
Faulty ignigtion switch?
Old Mar 4, 2008 | 08:05 AM
Axle/Gears: 4.1
it's not the ignition switch....
I checked that. The "run/after start" position stay energized when going to "OFF" (with the lead attached). If I take readings with the lead removed, then the "run/after start" terminal actually goes dead.
He has this LT1 in an old car, and I read somewhere that there might be some feedback and I might be able to install a diode, in a lead somewhere, to prevent this feedback. Any ideas?
Old Mar 4, 2008 | 10:20 AM
dingle's Avatar
Car: '83 Camaro
Well I had this same issue on my LS1 transplant and if I remember correctly the wire going to my thirdgen fuse block was not an igintion hot wire it was hot 24/7. After fixing that the car turned off.
eightsixseven
Dec 16, 2024 01:50 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
