Quick LSx-related question...
Old Mar 26, 2008 | 10:56 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Hey all,
While going through the local ads, I've found one offering a used Walbro 255 for $50. One way or another, I'll need one (or something similar) for my LQx swap anyway...
According to the seller, it was 'used for one month', he had two that he'd used 'as a double fuel pump in a track car' but then chose to go to a single pump that was larger. Part of me says "Jump on it!", & I guess the other half is skeptical. Are EFI fuel pumps one of those things that are generally OK to buy used??
Thanks guys.
Old Mar 26, 2008 | 11:55 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: Quick LSx-related question...
I don't see why not. its all matter of him telling the truth.
Have you thought about using an external pump at all???
Old Mar 27, 2008 | 06:37 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Depends on if he seems like he is reputable. Check his old posts... If you think he is being honest, then Ide say go for it. Thats the pump you'll probably need. And thats a price thats hard to turn down.
I wouldnt go external pump... Not when there are internal solutions that are easy and relatively cheap.
J.
Old Mar 27, 2008 | 07:23 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
For fifty bucks its a great deal and only a small gamble if it turns out to be cooked
Old Mar 27, 2008 | 11:24 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
DSM guys sell used walboro 255 pumps used ALL day.
Seems normal to me.
Old Mar 27, 2008 | 09:19 PM
V8Rumble's Avatar
Seems normal to me.
DING DING DING, we have a winner!!!
i was using them for a drag 1g talon. we were running E85 the whole time. we dynoed on one and did not have enough fuel pressure for 42lbs of boost and started to go lean up top, so for a quick fix we used a secondary pump.
Good call Aaron!
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
