Rear end questions
Old May 8, 2008 | 10:32 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Rear end questions
I have to change out my rear end, what are the best gear ratio's to use for 86 Camaro with 95 Lt1, and where on the net can I buy one
Old May 10, 2008 | 08:36 PM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
Axle/Gears: 3.27 9 bolt
Re: Rear end questions
what transmission are you using, is it a stock lt1?
Old May 10, 2008 | 10:41 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
it is the stock lt1 with headers, and I am using the 4l60e. Im wanting to change out my rear end because the 86 Camaro which I swapped the LT1 in was a 2.8v6 and has a 3:08 rearend ratio, no posi
Old May 10, 2008 | 11:55 PM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
my suggestion, and this is w/o really knowing what your overall plans are for the car..either 3.42's or 3.73
i'd personally go with 3.42's..plus its an easy set to get ahold of..since it was a common factory ratio...but thats just my opinion
Old May 11, 2008 | 10:13 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
when I first did my LT1 I used a 4l60e and 3.42s that worked pretty good for the street..
Old May 11, 2008 | 10:40 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
good deal, I just was going to get a hold of a 82-92 Iroc 3:42 posi rear end and swap it for my 3:08 so everything should line up(brake lines,etc....)
Old May 14, 2008 | 04:09 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
how much would it cost to build a ford 9" i have a complete 9" laying around but need to narrow it, and build it to handle over 500rwhp, right now my 84 t/a with an 02 ls1 and t56 is pretty stock, i have a powertrax locker in the stock rear with 3.73 gears, should the stock rear the way it is now hold up to a couple tests at the track?
Old May 14, 2008 | 05:34 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Normal launches will be fine, 4 grand launches with heavy powershifting it wont last long. I have the stock 02 Camaro rear end in mine, I have had it at the track on Nitto Drag Extreme tires with 2500 plus rpm launches and its fine. I also have a line lock. Its the sudden jarring that does in our small ring gears. If your worried just throw a set of Richmond grears in it, should be good to beat the tar out of up to around 400hp at the wheels. Thats what a Richmond tech told me. I had Richmond gears, 3.42 in my old setup, TPI 305 with a 6 speed 280ft lbs of torque at the wheels. I beat the hell out of it and never a problem. They are also relatively cheap and easy to set up, provided everything else in your rear end is good, when I did mine I only changed the gears themselves.
Old May 14, 2008 | 05:43 PM
Engine: 2002 Ls1
Transmission: t-56
for all i know the gears might be richmond, the powertrax is, what times are you running with the ls1?
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
