Please help me!
Old Jul 21, 2008 | 01:42 AM
TA 90's Avatar
Please help me!
I swapped an LS2 engine to my 89 trans-am and i'm having some problems with the power steering. It doesn't work properly, and the pump gets very hot. Should the pump work with old steering?
Old Jul 22, 2008 | 12:46 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Please help me!
I have the same question. Anyone?
Old Jul 22, 2008 | 09:57 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Please help me!
Can you be more specific than "It doesnt work properly."? Whats it doing?
If you are asking if the LS pumps will work with the older steering box...then yes. Im running the stock LS pump on my car with a standard box. Im pretty sure the LS2 pumps should work just like the LS1 pumps do.
If the pump is getting hot, it sounds like the steering is either binding, or maybe there is air in the system. Did you do the bleed procedure when first filling the pump with fluid? If the steering is binding, you probably have troule elsewhere in your steering...or in the box.
Toss us some more details...
J.
Old Jul 22, 2008 | 10:08 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Please help me!
I would jack the front of the car up, take the top off of the resevoir and with the car running, turn the wheels lock to lock several times to make sure that all the air is out of the system.
Old Jul 22, 2008 | 11:57 AM
Car: 86 Trans AM
Re: Please help me!
Oops...forgot to describe a bleeding procedure to see if you did it... But try what klortho said.
