LT1 swap transmission issues
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Transmission: 4L80E/4L80E
Only the '93 LT1's had the TH700R-4/4L60 transmission, so only the '93 throttle body has the TV cable mount.
'94-up had the 4L60E, controlled by the PCM rather than by a throttle valve.
Re: LT1 swap transmission issues
have a 700r4 in my 95. piece of cake. just use a speedo reluctor wheel and sensor from a 93 Fcar (relativly cheap from dealership), use the tbody accelerator cable bracket from a 93 fbody, 93 fbody or aftermarket throttlebody, and to keep it simple, just use a manual torque conv. lockup switch. I dont like those vacuum switch kits out there, very annoying when driving down the highway having that thing switch on and off constantly. I only used my lockup when racing, and on the freeway. jsut dont forget to turn it OFF. when you have the pcm tuned, have them use an auto tune format, but delete all functions/codes related to the auto. it needs to be auto cause of the amount of teeth on the speedo reluctor wheel compared to just using a manual trans tune. nothing else to it unless you have, and want to keep, a cable driven speedo. then you'll have to get one of those elct. conversion box's that will have a cable output to drive your speedo.
chris
chris
Car: 1992 camaro
Axle/Gears: 3:73
chris
chris
1992 Trans Am
Aug 8, 2015 08:16 PM
