Strange LT1 Tach problem- works until 4200rpm, then goes to zero
Old Sep 9, 2008 | 07:57 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I have a 1995 LT1 swapped into my T/A. I've tried two 3rd gen tachs now, with the same result. I've used a 8000 RPM tach from an L98 car that I know for certain worked perfectly with the original L98, and I've also used a 6000RPM tach from a 305 TBI car. For both, I will slowly accellerate and the tach will move up smoothly until 4200 RPM, then it drops off the table to zero and stays there until I drop below 4200 RPM again. The engine doesn't get choppy or anything when this happens, it appears to just be the tach that acts funny. Does anyone know what is causing this?
Old Sep 10, 2008 | 09:27 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: Strange LT1 Tach problem- works until 4200rpm, then goes to zero
Do you have it hooked to the tach output from the PCM? Mine did the same thing. I ran the white tach wire directly from the C100 connector to the coil and it fixed my problem.
Old Sep 11, 2008 | 06:07 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
yeah, i do have it running from the pcm. I'll have to try what you did. Thanks!
Old Sep 11, 2008 | 11:07 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Let me know if it works. It took me a while to figure it out.
midge54
Dec 27, 2019 04:14 PM
red90IROCls1
Aug 25, 2015 06:56 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
