coolant hose routing ?
Old Sep 26, 2008 | 11:56 AM
bmfIROC-Z's Avatar
i am running the stock 3rd gen radiator with the throttle body bypassed , i know the lt1 has reverse cooling so my question is how do i route the coolant hoses to run this setup?does anybody have pics of this?any help would be appreciated,thanks,joe
Old Sep 27, 2008 | 12:13 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: coolant hose routing ?
I just run the water pump to the sides it points to right side to right side radiator etc.. as for the steam line which is the reverse cooling section from the heads there is a fourth gen upper radiator hose that has a small line that runs into the main hose, I am not sure which one but it is posted on here and a search will dig it up.. or someone will chime in, or you can go to autozone etc. and look at the different year hoses and find one that has a small line branching off it.
I run an aluminum radiator with an AN fitting welded on which in turn runs to the steam line to return the coolant from the heads but it doesn't matter so long as it gets returned to the radiator somehow, DO NOT plug it off.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
