LT1 swap questions
Old Nov 27, 2008 | 11:23 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
LT1 swap questions
Ok, so as I'm building my lt1, I was wondering if you actually have to have an lt1 radiator? Or could I use my stock one? I know that lt1 uses reverse cooling so could someone answer that for me?
Old Nov 27, 2008 | 11:26 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: LT1 swap questions
I haven't done this, but when the Chevy raceshop first did this, they left the third gen radiator in the car and just played with the hoses.
Old Nov 27, 2008 | 12:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out the LTx swap sticky in the top section of this forum.
Old Dec 1, 2008 | 06:44 AM
TexasLT1's Avatar
Car: '92 RS
You can keep your thirdgen radiator. No need to swap in the 4th gen, though you can if you have it and want to.
Old Dec 1, 2008 | 06:03 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
go get this. http://www.autozone.com/images/produ...gy62055003.jpg
upper hose for a 94 camaro. use the branched off pipe to connect to the throttle body or if you are doing the throttle body bypass just connect it to the other hose on the passenger side of the throttle body.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
