LS1/4L60E Spohn components
Old Feb 6, 2009 | 03:53 AM
screeminchicken's Avatar
Has any of you swappers completed or in progress with a LS1/4L60E swap and used Spohn motor mounts and Spohn trans X-member ?
or am I the 1st one?
I would like to find out your experiences and also get some pictures of clearence with the oil pan and stock K-member and also a picture of the Spohn X-member installed with the 4L60E.
I have been searching in this section.. looks like many of you are done or doing LS1/T56 swaps.
Old Feb 6, 2009 | 04:36 PM
birdonnos's Avatar
Re: LS1/4L60E Spohn components
i am fixing to swap a lq9 and 4l60e in my car using the same mounts above so i am subscribing
Old Jun 10, 2009 | 12:06 AM
knight2kLS1's Avatar
I just got my motor and trans in with their mounts and x member. stock k member clearance is real tight on the oil pan and had to do some pushing on the trans to get the trans mount to line up with the bolt holes. weird.
Old Jun 10, 2009 | 11:21 AM
I notched my stock k-member doe a/c and oil pan clearence. The Spohn motor mounts fit nice. Just had to dril a pair of holes for the 4th mount bolt(extra).
The trans X-member didnt line up for some reason. about 1.5" to 2" off.
So I am ditching that and getting SSW long tubes instead and making my own X-memeber.
Plan is to make em out of 2X4 wood and then take it to a shop and ask them to replicate.
Old Jun 10, 2009 | 02:22 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Interested in selling the 4L60E Spohn crossmember then?
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
Briandrex
Oct 5, 2015 06:20 AM
buckshot63
Sep 10, 2015 09:15 AM
