lt1 cai question
Old Mar 27, 2009 | 02:39 PM
ProjectX's Avatar
Car: '91 Camaro RS
Transmission: 4l60e
Axle/Gears: stock 2.73's :(
lt1 cai question
I was looking at the slp cai for the lt1's, and I have a couple questions.
- Does it fit in the engine bay of a 3rd gen?
- If it does fit, is it worth dropping it in or is the stock setup with a open element filter sufficient?
Old Mar 29, 2009 | 06:50 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: lt1 cai question
Probably not.
The open element will be sucking in tons of hot air(my problem).
Making a custom one would probably be the best route, if you do let me know how it goes!
Old Mar 29, 2009 | 08:44 AM
ssean92's Avatar
Car: sold
I bult one that feeds my lt1 383 well
Old Mar 29, 2009 | 09:17 AM
BCdawg57's Avatar
Thats kind of what i had in mind only going the other way. What did you use exactly? Looks like PVC pipe. what diameter? and what did you use to connect it to your maf?
Old Mar 29, 2009 | 09:34 AM
ssean92's Avatar
Car: sold
I used 3" pcv piping and lowes sells a adapter that is rubber inside with a metal outside with clamps. it is in the pluming section also
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
