Radiator question
Old Mar 30, 2009 | 12:00 PM
83trnsamLT1's Avatar
Car: 1983 Trans Am Recaro
Engine: Lt1
Radiator question
A 94 camaro radiator should fit into my 83 trans am, right?
Old Mar 30, 2009 | 05:02 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: Radiator question
It will work I think that it sticks out a little. If you are doing the LT1 swap your old one should work.
Old Mar 30, 2009 | 08:31 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
stick with your old rad. if you put the new one in you'll have to modify your shroud. you can get coolant hoses that fit from the old rad to your lt1 perfectly. And if your old rad is in bad shape, purchase a new aluminum one from a local garage/rad shop/parts place and it will go with the rest of your lt1s aluminum parts, thats what i did. I believe the old ones are copper. IF you do decide to get an alum. rad use the yellow peak global coolant... it wont corrod the aluminum heads/rad/etc.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Clean87TA
Sep 4, 2015 11:23 PM
redmaroz
Aug 16, 2015 11:40 PM
