Swap Lt1 Fuel Question
Old Apr 2, 2009 | 11:52 AM
83trnsamLT1's Avatar
Car: 1983 Trans Am Recaro
Engine: Lt1
So all I have to do when swapping in the Lt1 to get the fuel right, is to change pumps and fix the ends on the line that goes to the motor. Is there anything else you guys can think of that i'm missing? Like what about the charcoal canister and what about the vapor lines? Can i just get rid of that stuff or do I have to keep it.
Old Apr 2, 2009 | 08:27 PM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
Re: Swap Lt1 Fuel Question
You can hook up all the EVAP canister stuff and it will cut down on your fuel smell, or you can leave is all unhooked. It isnt going to make the car run any different but you may get a constant fuel smell from the car because the tank is venting out to where you can smell it. Mine isnt hooked up yet but will be doing something to help with the smell.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
