91 TPI to 93 LT1
Old Apr 12, 2009 | 11:34 PM
89 T-TOPd RS's Avatar
91 TPI to 93 LT1
ok i know there is alot of posts on this topic but i have a couple questions i have come across with all the posts.
painless wiring harness- is that just a plug in system into where the old wiring harness is? if not wat modifications to the harness am i going to make. i live in Jersey so im geussing i need the emission stuff.
what exatcly is VATS?
feul pump- ive heard the TPI feul pumps will work with the LT1. its enough pressure? is a 350TPI feul pump different from a 305TPI pump?
motor mounts- anyone have a part number or sumthing?
trannys?? ive found a 93 LT1 w/ alm heads i have a turbo 350 i got off a buddy but i dnt want the 3-spd. which trannys will bolt up with this that driveshaft mods will not have to be made?
also the 91 has an electric speedo correct?
also i dnt care about the a/c will i run into problems going without beside the belt?
thanks Jeff
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Sanjay
Aug 12, 2015 03:41 PM
