6.0 fuel pump
Old Apr 21, 2009 | 09:18 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
6.0 fuel pump
ok, i need to figure out a fuel system for my 6.0/t56 swap. a stock ls1 plastic tank pump shouldn't really have a problem supplying a truck 6.0 should it? i'm trying to decide if i want to just stick a walbro pump into my stock tank or get a plastic ls1 tank and fight with the fuel gauge. any thoughts?
Old Apr 21, 2009 | 02:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 6.0 fuel pump
Use the stock LS1 pump, it should be fine.
Old Apr 21, 2009 | 02:37 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: 6.0 fuel pump
easiest method is to use walbro 255lph pmp in your stock tank with c5 fpr/filter, with fuel return located near tank off fpr/filter
and fbody ls1 fuel rail. if using ls1/ls6 intake
if do not want to use c5 fpr,
use aftermarket fuel rails with fpr, and adapter fittings for stock fuel lines.
your stock tank with walbro will be enuff for n/a 6.0
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
