lt1 question
Old Jun 9, 2009 | 05:13 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
lt1 question
Hello, this may not be the right place for this question, but anyways I have my new engine build plan. The only thing I'm unsure of is what drives the oil pump in a LT1? This seems like a very basic question but I've had trouble finding an answer, without a distributor is there a drive shaft that mounts on the cam drive gear? And would it be able to mount in a gen 1 block? The reason I ask is I am planning to go with a distributor-less ignition system and see it as a simple way to lose the tpi manifold for a simpler lt1 manifold.
Thanks, Kenny.
Old Jun 9, 2009 | 08:36 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: lt1 question
There's a stub shaft that goes in place of the dizzy, so the cam still drives the oil pump.
Can you mount it to a 1st gen block? I would think so, but it would require some machining, I would think...
Old Jun 9, 2009 | 09:30 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 question
The shaft is held down by a piece that bolts inside the block behind the hole where the distributor would go, if the block is not machined for the bolt you would have to do that (if it is possible)
Old Jun 18, 2009 | 03:32 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: lt1 question
Sorry for the late reply, I've had family visiting. Thank you both very much I guess I'll be talking to my machine shop about setting it up for me.
thanks again, Kenny
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
