quick LT1 question
Old Jun 30, 2009 | 05:14 PM
TPImoneypit's Avatar
quick LT1 question
Ok I've read the stickies and im pretty sure I understand it, but just wanna clarify before messin somethin up.
Puttin a LT1 in my buddys '86 z28. The donor car is a '97 z28, and I had read that someone had a more difficult time splicing into the harness with the OBD II setup. I then read that to run OBD I, all you had to do was plug the OBD II harness into an OBD I pcm. Is there anything else to that or did I already read it correctly?
Old Jun 30, 2009 | 06:06 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: quick LT1 question
There is more to it than pluging a OBD II harness in to a OBD I pcm.
Old Jun 30, 2009 | 08:47 PM
What else has to be done to convert the system from OBD II to OBD I?
Old Jun 30, 2009 | 09:13 PM
Firebat's Avatar
LT1 OBDII harness is nothing more than a 95 OBDI harness with extra wires:
http://shbox.com/1/1995_pcm_conn_a.jpg
http://shbox.com/1/1995_pcm_conn_b.jpg
http://shbox.com/1/1995_pcm_conn_c.jpg
http://shbox.com/1/1995_pcm_conn_d.jpg
http://www.ls1tech.com/forums/lt1-lt...-i-96-z28.html
You're still going to have to splice in the LT1 harness but a 95 LT1 OBDI PCM(maybe 94) will work off of a OBDII harness.
The 97 has a different knock sensor. You will need to swap in a 94-95 LT1 knock sensor.
Old Jul 1, 2009 | 12:48 PM
Awesome, that's exactly what I wanted to know. Thanks man
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
