1982 MIL vs LS1 MIL
Old Aug 17, 2009 | 12:46 PM
screeminchicken's Avatar
1982 MIL vs LS1 MIL
I got part of the dash working, so I thought I would start to figure out how the get the MIL or check engine light to work.
Come to find out its not that straight forward.
On my 1982, the ECM sends a MIL signal to a light driver module which in turn sends a voltage to the MIL bulb to turn it on.
On the LS1, the PCM sends a MIL signal to the BCM, which in turn sends serial data over the the LS1 gauge cluster which then interprets the signal and turns on the MIL bulb.
I am stumped here, what did you guys do ?
Old Aug 17, 2009 | 05:15 PM
kevinc's Avatar
Car: 1982 Z28
Re: 1982 MIL vs LS1 MIL
Your LS1 sounds very different from my LS1, I just connected the PCM MIL output to my in-dash Check Engine light and it works as designed.
I'm running an '01 LS1, PCM, and harness...no BCM at all.
Old Aug 17, 2009 | 07:07 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Same here, there was a brown/white wire that came from the instrument cluster and went to the connector for the old computer. I cut this wire and sent it to my new LS1 computer and it works just fine. But this was on my 89 IROC and i'm sure it's different on your 82, I'm trying to find a schematic on Austinthirdgen.org and it's not showing SES light in their diagrams. The SES or MIL has 12 volts in run/start and the PCM is what grounds it. I'll try to look around some more and see if I can find a diagram.
Old Aug 17, 2009 | 07:47 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
The light driver module was on older cars... I had this on my '85 iroc as well and it will cause the output of the ECM to be inversed if you connect to it... ie your new ECM off will cause the MIL to be on, and ECM MIL on, will cause dash MIL light off
The light driver module is behind the dash pretty much behind the radio / vent controls... it is taped into the harness on the '85... what i did was simply cut it out and tied together the input wire to the module to the output wire (i had the input wire being driven by my new ECM as i brought it in and mounted it in the same physical space of the old ECM.
it is as simple as that
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
