power steering line
Old Sep 21, 2009 | 11:52 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
power steering line
i have my ls6 installed and i am in the process of wiring etc. i know where the pressure port is on my gto pump but i am not sure which port is the pressure on the steering box. is it the front or back hole? thanks for any help.
Old Sep 21, 2009 | 01:49 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
Re: power steering line
should be the back port, but to check its the one with crimped ends on the hose on both ends. the return line has one end that is just a cut off rubber line, not a pressure fitting
Old Sep 21, 2009 | 01:51 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
thanks for the help. i found a picture online.
Old Sep 21, 2009 | 02:26 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
inlet is a M18x1.5, outlet is M16x1.5
so the inlet is bigger then the outlet.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
mdtoren
Aug 23, 2015 12:52 PM
