More LT1 Wiring
Old Oct 11, 2009 | 03:48 PM
carkook's Avatar
More LT1 Wiring
Im using the 93 f body LT1 engine bay harness and the rest from my 92 rs 305 TBI.
I just want to the car to be able to run and drive, then Ill figure out the rest like the aldl stuff and get the speedo working. Im gona have the ecm sent to get the vats removed. But for now this is what I have and am hoping will get it running
For the LT1 harness
c100
PIN A-Power feed from injector fuse 9 going to a switched 12v source
PIN G-Power feed from ignition fuse 11 to a switched 12v source
PIN K-Power feed from injector fuse 10 to a switched 12v source
c210
PIN A-Starter 12v source to B4 C100 Starter wire(purple)
PIN B-ECM ground to ground
PIN C-ECM battery feed to A4 c100 constant 12v
C220
PIN J-Fuel Pump Relay Control to G4 of c100 Fuel Control gray wire
PIN F-Fuel pump feed too ????
C230
PIN G-Power feed from ecm ign fuse 5 to switched 12v
Old Oct 11, 2009 | 09:36 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: More LT1 Wiring
Is the computer from a '93 as well? If it isn't,you'll have to swap it out for a '93, if it is then all you need is a chip burned to take the vats out, most end up using a '94-95 PCM and harness since the '93's are a totally different beast.
Old Oct 11, 2009 | 11:48 PM
carkook's Avatar
Re: More LT1 Wiring
yes the ecu and harness are from the same car, so in coming from someone who has done this before it will start up the first time if its wired as I showed?
Old Oct 13, 2009 | 06:21 AM
Klortho's Avatar
Car: 1987 GTA
Re: More LT1 Wiring
To be honest, I don't know, it looks right but like I said, the '93 is a breed of it's own and was different than the others.
Old Apr 20, 2012 | 11:50 PM
sum_drummer_16's Avatar
Car: 1983 Z28
Engine: Lt1
Transmission: t5
Axle/Gears: 4th gen limited slip
Re: More LT1 Wiring
Hey, I realize this is a pretty old post, but I'm working on an lt1 swap. There are two power distribution wires on the third generation c100. A4 I see is constant 12v. Are they both constant 12v or is one switched? Also, if they are both constant, then where did you pull your switched 12v power from?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
