quick power steering question
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
do i have to use an f-body power steering pump or will any gm pump work that is of the newer style pump (with remote reservoir)? i planned to put the power steering back in the car before i started the swap, but with the cost of the pumps, and the fact that i didn't luck out and start with a complete dropout (ie, i had to buy EVERYTHING individually), the cost put it out of reach. i had an s10 box in the car anyway, so it wasn't a super big deal.
well, now it's a big deal. especially with an iron block going in soon. i have a newer style pump at the house already from a 3.8 camaro. will it work with the f-body PS pump bracket? the brackets are CHEAP...like $12 on ebay, may even find one locally. either way, the pumps look very simliar based on the pictures i have been able to find of the ls1 PS pumps. i've never held one in my hand though and i'm not sure of the differences. so far, the only differences i can see is where the feed line goes into the pump. the reservoir would have to be different then the f-body pump, but that can't be too hard to fab a solution for that.
discuss
discuss
Transmission: 4L80E/4L80E
The f-body pump doesn't have a remote reservoir. But, if you can get it to fit in the brackets and get the pulley to align, you shouldn't have a problem.
Engine: Cammed 6.0L LSX
Re: quick power steering question
Just make a wanted ad on LS1Tech, you'll have like 5 people telling you they will sell you their ps pump within a matter of a day or two. I'd bet you won't pay more than $40 or $50 for one.
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I bought my complete setup including brackets, pump, resevoir and all lines / pulley for $70 on LS1Tech.
Do they work fine with the stock steering box? Do you need any special fittings/adaptors to hook them up?
Engine: 7.0L
hey crossfire, i just saw that you dug this up. they work fine with the stock box, and the stock 98-02 line goes right into the box with no issues. it doesn't lay very well, so i plan to redo the line when i put the box back on (took it off early this season when i was chasing my butt trying to run a number).
LOL... I just noticed your response...
Doesn't matter, I'm working on this at the speed of mud... I still have all the parts sitting in my garage blocking the door in the plastic bin that the PO dropped it off in (they were used and leaking fluid through the side of the box). I still intend to do it, if I ever find time to work on the car again.
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
