lt1 will not run help
Old Oct 22, 2009 | 09:30 PM
underdog891214's Avatar
Car: 1985 firebird
Engine: olds 350
Transmission: th 350
Axle/Gears: stock
i have a 94 camaro with a lt1 it will run for 5 secs and will shut off plz help
here is a list of new parts
fuel fliter
plug and wires
ignition coil
igniton module
new ecm
new msd optispark dis
new o2 sensor
here is codes
45 rich exhaust
44 lean
43 esc module
42 est
55 defective ecm
54 fuel pump relay
53 system voltage high
51 ecm prom error
Old Oct 24, 2009 | 02:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: lt1 will not run help
Sounds like it was wired wrong, bad PCM and/or something bad in the fuel system
Old Oct 24, 2009 | 07:25 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Actually, it sounds like the VATS isn't programmed out of it
Old Oct 24, 2009 | 11:18 PM
Pocket's Avatar
Car: 91 Trans Am
Really?
Rich + lean (with knock) + excessive voltage + prom issues?
Old Oct 25, 2009 | 05:27 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Thats is what I was thinking but he said it was a 94 camaro.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
