Modest 6.0 Build, what can I do?
Old Nov 3, 2009 | 04:18 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm thinking about going the 6.0 route come tax time and I was thinking of something pretty modest, like in the 400rwhp range. What would be the most economical way to go about this? I want to use an auto because I'm not really into sticks, so a built 4l60/65E would be a must. What do you guys recommend?
Like I said nothing too crazy because 400rwhp in a 2800lb car is more than enough for me, lol
Old Nov 3, 2009 | 04:27 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Modest 6.0 Build, what can I do?
Pretty easy to hit close to that power level. Over 4 is gonna cost you typically, Under 4 is affordable thats a threshold for LS1 power vs affordable. Cam, Longtubes, Fast intake, and a good tune will get you there. I'd run the patriot head/cam kit that will put you well over and its under $2k
Old Nov 24, 2009 | 01:48 AM
Ok that sounds pretty good but I also have another question for the masses. If and when I do this swap I want it to be as "bare bones" as possible. Here's an idea of what I'm thinking of.
I want basically the same set up or I was thinking a multiport type single plane with a adequately sized TB on top. I'm tossing around the old school look as well. What can I do to be able to run the bare minimum and be able to drive the car? I'm talking as far as wires and accessories. To give you an I dea of what I'm running now here it is.
Old Nov 24, 2009 | 02:56 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You can get 400 or so with a LS1, so a 6.0 is even easier, just good heads and cam make them get there.
Old Nov 24, 2009 | 06:11 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I've got a buddy who built an LQ9 for his '94 Trans Am and put the Victor Jr EFI intake on it with an 1100 CFM TB, I know someone on here did that as well.....you get the looks of a carb, but stay EFI. I remember him saying it made around 560 or so at the flywheel.
here are two vids of his with specs in the info
http://www.youtube.com/user/formuliz.../1/xY_pXghM2hY
http://www.youtube.com/user/formuliz.../4/6iZRqshJQBw
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
