correct me if I'm wrong (coolant bypass/steam tube thingy)
Old Nov 9, 2009 | 07:14 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Correct me if I'm wrong, but is it true that if you run a rubber hose from the small outlet on the stock 3rd gen radiator right by the radiator cap, to the coolant bypass tubes that are right under the intake manifold, you DON'T have to drill and tap a nipple on the top of the water pump?
What I'm talking about is what this guy did:
https://www.thirdgen.org/forums/atta...s-settings-cat
That hose goes to the radiator here:
This is something that has confused me for a while. I'm really like to not have to drill a hole in the water pump if I don't have to.
Old Nov 9, 2009 | 07:21 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: correct me if I'm wrong (coolant bypass/steam tube thingy)
I didnt want to drill and tap mine either so I put a piece of stainless tube in the middle of the upper rad hose with a nipple on it and hooked it to that. Heres a crappy pic where the blue arrow points is the place
https://www.thirdgen.org/forums/atta...gine_compt.jpg
Old Nov 9, 2009 | 07:47 PM
BlueZee28's Avatar
Did you just cut the radiator hose in half and use the tube as a slip fit design with hose clamps?
I think I read somewhere that you had extra parts to make another one of those? Do you still?
Old Nov 9, 2009 | 07:50 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yes thats what i did and yes i have more pieces here somewhere
Old Nov 9, 2009 | 07:56 PM
BlueZee28's Avatar
PM sent
Old Nov 10, 2009 | 03:53 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Nick, here's how i ran mine:
Woulda been better to use a small hose length to the fitting, but this held up.
Old Nov 10, 2009 | 07:02 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Nick - mine is the same routing as Sheldon's. I used a small length of hose coming off of the radiator with a converter at the end of it (to shrink down the opening) then the small coolant hose (same size as Sheldon's).
Old Nov 11, 2009 | 12:59 AM
BlueZee28's Avatar
So that little hose goes to the bypass tubes under the intake, by the throttle body right? And since you did it that way, you don't need the waterpump drilled with a nipple, that hose serves the same purpose?
Old Nov 11, 2009 | 08:47 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Yep! Technically its suppost to pass through the underside of the TB, but thats for winter driving purposes. We dont care about that
No need to drill the waterpump, i simply ran my hose to the nipple shown, and called it good.
Old Nov 11, 2009 | 11:22 AM
BlueZee28's Avatar
Ya I am going to cut off the nipples on the throttle body since I won't be driving it when it is cold.
Old Nov 11, 2009 | 04:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by SheldonZ28
I was thinking of using that nipple on the radiator, but hadn't decided how to do the change in hose size.
Another option is to drill & tap the power steering cooler (which I happen to have).
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
Papaginos
Sep 27, 2015 03:29 PM
GTAman
Sep 21, 2015 09:57 AM
sunbound
Sep 5, 2015 11:52 AM
