LSX project
Old Nov 14, 2009 | 05:05 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
LSX project
havent been here in awhile, i ran into some problems that only money can fix..neways just wondering if you can swap everything (crank rods and pistons) from a 5.7L LS1 in a 4.8L..just wondering if the block and bores are the same..thanks guys..
Old Nov 14, 2009 | 08:19 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
Re: LSX project
i have seen post with guys that have bored a 5.3 to 5.7 not sure on a 4.8.
Old Nov 15, 2009 | 12:24 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX project
4.8/5.3 blocks are identical
They can be opened up to a 5.7 no problem with just a bore
Old Nov 15, 2009 | 01:40 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: LSX project
Just as said, t he blocks are the same between the 4.8 and 5.3. With the 5.3 you can keep the same crank and I believe rods. The 4.8 will need a new crank as well since it has a shorter stroke.
Not sure what your situation is, but if you are buying everything, then the 5.3 might be the cheaper way to go. Otherwise, if you already have the internals, go with whatever block you can get the cheapest.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
