5/16 line to -6AN hose
Old Dec 6, 2009 | 09:23 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I'm getting close to sorting out the rear fuel lines and have a slight issue with the return portion... this is an LS1 swap.
I went with -6AN from the tank down to the body. The -6AN hose isn't exactly ideal for the 5/16 line it needs to connect to. The new lines are SS so i'm not sure if I can use one of those Earl's hard-line AN tube fittings (JEGS p/n: 361-165056). They claim 50 PSI max which should be ok for the return side right?
Old Dec 6, 2009 | 09:43 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: 5/16 line to -6AN hose
Simply put, yes.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 20, 2015 06:59 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
