94' LT1 vats question
Old Jan 11, 2010 | 01:17 PM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
im doing an lt1 engine swap and just have the computer. no resistor key or theft deterent module.
i need to produce the 50hz with 50% duty cycle signal to the fuel enable signal wire that goes to the computer so that it will enable the fuel system... more importantly the injectors.
does anyone have a simple and legible diagram of passkey2 bypass module. the one that uses the 555 timer, a couple of diodes and a couple of resistors and some other stuff... i don't really know the entire parts list because i haven't seen it done or a clean legible diagram of it.
thanks in advance.
Old Jan 11, 2010 | 02:31 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 94' LT1 vats question
Just tune it out of the PCM. Its a simple check flag
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
