fuel pump relay
Old Feb 13, 2010 | 12:09 PM
bad67ss's Avatar
Car: 92 Z28 LS1 4L60E swap
fuel pump relay
Final wiring question i hope. On the fuel pump relay i have a green with white stripe wire is this my trigger wire for the ls1 pcm? Also have a red wire does anyone know if this is just a positive wire?
Old Feb 13, 2010 | 12:59 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: fuel pump relay
green + white is pcm control for the LT1, I would assume it is the same for you. Red should be +12V, where does it come from and where is it going?
Old Feb 13, 2010 | 01:55 PM
bad67ss's Avatar
Re: fuel pump relay
the red wire goes from the relay to a single wire connector? not sure if its 12 volts or something else. forgot to mention car is a 92
Old Feb 14, 2010 | 07:33 AM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel pump relay
Red is fuel pump prime connector. It doesnt get connected to anything, it is for testing purposes only. Add 12v to it and the pump will prime regardless of the engine or ECM/PCM status
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
