LS1 wont fire!!!!!
Old Mar 7, 2010 | 10:27 AM
oners2nv's Avatar
Car: 1992 Z28
Engine: Magnacharged heads cam lq4
Axle/Gears: strange s60 4.10
LS1 wont fire!!!!!
I just completed my ls1 swap. I have a 99 ls1 from a Trans Am. It only has 4,500 miles on it. I can get it to turn over but it wont fire. I have spark and good fuel pressure. I disabled the vats from the ls1 but not the 91 camaro. The injectors are not pulsing. Any ideas? I also replaced the crank sensor and the ls1 is not throwing and codes.
Old Mar 7, 2010 | 10:38 AM
oners2nv's Avatar
Car: 1992 Z28
Re: LS1 wont fire!!!!!
I thought I would add I am using a full plug and play harness from Speartech. I have checked all my fuses and they are all good.
Old Mar 7, 2010 | 12:57 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
If the injectors are not pulsing its a VATS issue within the LS1 PCM. If the injectors are firing ( use the test light injector trick google it ) anyways if they are firing but not shooting fuel then verify your fuel pressure. It should be 58-61psi and no higher. Higher PSI at the rail can keep the injectors from opening ( they're just little servos in there ) and failing that? While cranking the engine over try tapping each injector on the side of its body one at a time with the end of an 8" or so 3/8" extension. When they sit for a long time sometimes the get seat stuck. A lot like a starter that needs a tap to shake the brushes a little before it will crank.
Old Mar 7, 2010 | 03:27 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Cam and crank sensor good?
Old Mar 7, 2010 | 05:39 PM
oners2nv's Avatar
Car: 1992 Z28
I tapped on the injectors and it fired right up. Thanks for the help, it sounds like it has been running this whole time.
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
