My 82 Z build
Car: 82 Z28
Engine: She's motor-less!
Transmission: th-350
My 82 Z build
Well ive owned this car since i was 18, now am 23...since then ive had a kid which slowd down the build alot! When i get time from work and away from the gf kid..i try to get work done! right now ive been foucusing in the body work (trying to learn by doin myself, so bare with me)..then collecting parts for my swap..
the back half is all primerd, just 1 or 2 spots to fill..
Cardoorb4prime.jpg?t=1268370761
the front end is off and primerd, needs a few spots plastic filld but overall in good condition..
frontdriver.jpg?t=1268370881
frontclip2.jpg?t=1268371029
the pass-side is all in primer now, just a few spots to massage...
doorprimer.jpg?t=1268371633
heres a pic of the color scheme i got it with, i plan on going back to the same colors (so the interior matches)
wingcolor.jpg?t=1268371731
ALRIGHT, time for the funner stuff....Stock bottom end lq4, 317 cast heads..going carbd (for money reasons and theres 1 other ls swapd thirdgen in my town and its f.i.) Bought the motor for cheap b/c it was a parts motor for a guy locally. So it took time to find fbody accessories/oil pan set up..
FMotorClose.jpg?t=1268371197
picture speaks for itself..
Spohnmtmounts.jpg?t=1268371282
may not look like much but its a th350, with b&m insides..(bought from a friend for 200$)
BMtranny.jpg?t=1268371338
more fun...
6LSmsd.jpg?t=1268371408
.....its a slow build, but im starting to get a little more motivation to get it running and finished!
Well hope you enjoi
more fun...
Well hope you enjoi
Transmission: 4L80E/4L80E
Carb'd LSx - personally, I don't see it as less expensive. Looks like you're starting with a bare long block; you could get LS1 take-off parts for a lot less than what the carb LSx parts are going to cost you. Granted, if you want a better intake than the LS1, you will spend more money for that. You didn't mention cam, can we assume stock LQ4? LS1 parts will handle that pretty well. Carb can't compete with EFI on the street, but if this is a weekend toy - well, I'd still do EFI.
What are you planning for a torque converter on the TH350? Corollary question: What year is your LQ4? Did the 317 heads came on it? You'll probably need to do something "special" to use the TH350 on the LQ4.
Car: 82 Z28
Re: My 82 Z build
I understand that efi is easier to tune, better mpg and whatnot...But theres only 2 ls-swapd thirdgens in my town and i want to do it differently then him! Plus i like going this route b/c later on down the road with a little more funding..i can drill the fuel injector bosses on the carbd manfiold, put a spacer and throttle body on it..plum sum extra wires and fuel stuff and BOOM, got a fuel injected ls...and maybe with a little more luck, i can throw a little 76 trim turbo on there!
My whole goal rite now is to get the motor in the car..running with this route, on a very limited budget!
As for a tq conveter, gonna run a th350 style converter...already bought a 6.0 flexplate with a spacer to allow the th350 to bolt up to ls motor...
And off the top of my head, i dont remember what yr motor it was....but here are the heads that came with the motor
heads.jpg?t=1268468070
317castupclose.jpg?t=1268468150
they were hot tankd, fluxd and milld 010". i think they might be off of a fbody but could be wrong!
No, 317's are from LQ4's. Like 243's but with larger chambers.
Reason I asked is the early LQ4's with cast iron heads had a longer flange on the crank where the flexplate/flywheel mounts.
