LT1 swap
Old Apr 30, 2010 | 02:01 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
LT1 swap
Found a 97 Camaro with a good LT1, 4L60, and rear end. $1800 for the whole car, except the steering column..he he
Here she is:
Old Apr 30, 2010 | 02:03 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT1 swap
Ouch!
Now the fun begins.
Old Apr 30, 2010 | 03:10 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 swap
Looks like a good donor. plenty of parts to resell and make your money back
Old Apr 30, 2010 | 03:30 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT1 swap
It seems like a good deal, to me, for $1800.
I'm trying to find a thread that shows what needs to be done to the stock crossmember, so the 4L60 tranny will mount to the darn car. I can't find a thread that shows any specifics.
I wonder if I could/should swap in the entire fuel tank/pump assembly to my 86, as well. Hmmm. Hmmm.
Old Apr 30, 2010 | 03:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 swap
I recall a few threads of modifying the stock crossmember. They chopped the xmember at the mount and welded thin plates moving the location back a few inches. Lining it up is easiest when the engine is bolted to the K-member. Id suggest setting your pinion angle before the welding the finishing pass. Its a bit trickier that way
Old May 4, 2010 | 03:26 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: LT1 swap
ive seen a couple threads out there doing the 4th gen gas tank swap..TPI TERR did one i think....
Old May 4, 2010 | 06:02 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT1 swap
I'll look up the gas tank swap. Thanks!
Old May 4, 2010 | 07:34 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 swap
Nothing special about the 4th gen tanks, they're metal until '99 when they swapped to plastic.
Old May 4, 2010 | 09:59 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 swap
Metal tank swaps gain nothing. The plastic tanks dont gain much either aside from an extra gallon of capacity
Old May 4, 2010 | 10:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're starting with a carb'd car, it adds quite a bit. . .
Old May 4, 2010 | 10:59 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT1 swap
I was figuring doing the swap and using the entire 4th gen fuel pump/tank assembly might get rid of my noisy fuel pump issue, plus it would be a newer fuel pump, which can't hurt.
Old May 5, 2010 | 07:20 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT1 swap
I found this page to be the most clear and understandable, as far as wiring goes. The harness plugs are all labeled, and there are charts that show which wires are used/kept and which wires are not used/kept.
http://www.lt1swap.com/all_lt1.htm
I guess the wires that are not used are the same, no matter what you're swapping the LT1 into. That's how it seems, from the info on this page, anyway.
Once I take out the 305 tpi and dig into the engine bay of the 97 Camaro, more things will become evident and clear.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
