4L60E (ready to scrap my car)
Old Jun 2, 2010 | 08:54 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I posted this on LS1tech but figured I may as well try here too.
Ok here is my predicament. I am swapping an LS1 and 4L60E into my '91 Trans Am (originally a 305 / 700R4) I bought the engine locally and the trans from a classifieds ad online nearby. The 4L60E was not from an fbody, it looks like a GMPP trans. It was basically brand new never used. Came in the crate. Anyways, I swapped an LS1 fbody tail housing on already, and put the trans in the car, got the swap pretty much all buttoned up. Anyways I am putting the driveshaft in and realize that it isn't even touching the output shaft on the trans it is so short. (The output shaft) Why I didn't realize this earlier I have no clue and it's my own fault.
But I want to know if the GMPP tranny's came with a different output shaft from the fbody unit?
If so can I swap it in the car?
I've been working on this car for months and really can't backtrack anymore. I am ready to just scrap the car and buy an LS1 fbody instead of a 3rd gen. Which would be thousands lost lol.
If I stick my finger in the end of the tailhousing I can't even touch the output shaft. I am using a 3rd gen aluminum driveshaft.
Old Jun 2, 2010 | 09:02 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: 4L60E (ready to scrap my car)
sounds weird bro. im using a 4L60E from a 06 gto. it fits perfect with the aluminum drives haft i have. take some pics of the trans
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I'm using a B-body 4L60E in my LT1/4l60e swap and had no problems with the stock thirdgen alu. DS.
There are several valvebody and internal differences between the 4L60E's over the years but externally they are basically the same length as far as I know. But i've only ever really looked at F and B body 4l60e transmissions.
Old Jun 2, 2010 | 09:29 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
did you two swap the tailhousing to an f-body housing? what the OP is saying he swapped the tailhousing to an f-body one and it sounds like the output shaft is different.
Old Jun 2, 2010 | 09:32 PM
Pocket's Avatar
Car: 91 Trans Am
You sure its not a 4WD 4L60E? Tailshafts are different lengths for 2WD and 4WD
Old Jun 2, 2010 | 09:34 PM
No, its just a straight B-body 4L60E no changes. Bolted right in and my DS fits like stock.
Old Jun 2, 2010 | 09:43 PM
RockJay81's Avatar
same here straight gto trans check the tail it might be a 4wd
Old Jun 2, 2010 | 10:19 PM
Shift06's Avatar
Yeah I swapped to an fbody tailhousing. I have no clue if it was a 4x4 trans, I didn't assume so because it is a GMPP trans and came with one of those orange plastic 2WD style tailhousing's on it. From the end of the output shaft to the edge of the fbody tail housing is about 4.5".
Old Jun 3, 2010 | 06:19 AM
Pocket's Avatar
Car: 91 Trans Am
I think you got the 4WD unit...
Old Jun 3, 2010 | 02:14 PM
Shift06's Avatar
I think so too judging by the pic posted on tech.
http://www.ls1tech.com/forums/automa...l#post13416342
I know this is gonna require me to remove the tranny and tear it apart, which depresses me, but is it as simple as buying the proper output shaft, or do you think there will be other components required to swap it as well?
Old Jun 3, 2010 | 03:07 PM
Klortho's Avatar
Car: 1987 GTA
It would probably be easier finding an f-body 4L60E and putting it in.
Old Jun 3, 2010 | 03:23 PM
Shift06's Avatar
That was my original intent, but it seems like fbodies don't exist here.
Old Jun 3, 2010 | 03:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you know your way around the insides of auto trannys, swapping out the output shaft would be a reasonable option for an otherwise "new" transmission. But, all of the guts will have to come out, as the output shaft is the first thing that goes in the case (which you would know if you know your way around the insides of auto trannys).
Old Jun 3, 2010 | 03:31 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Don't give up on it just yet. Your so close. It sounds like the quickest fix would be to find another 4L60E from and f-body or b-body. Maybe check craigslist or local classifieds. You could sell the tranny you have now (you said it was new, right?) and cover the cost of another tranny. Good luck and keep the faith, your almost there.
Old Jun 3, 2010 | 03:51 PM
Shift06's Avatar
Which I don't, so I may be looking for a new trans :'(
Old Jun 3, 2010 | 06:57 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Why not get a quote from a tranny shop for how much they'd charge to swap output shafts? It may be worthwhile.
Old Jun 3, 2010 | 07:08 PM
Shift06's Avatar
Yeah I may try that, I am so close to having the car ready to start though and I was just really disappointed to find this out. Putting the driveshaft back in was one of the few things I had left to do. Oh well.
Old Jun 3, 2010 | 09:17 PM
Pocket's Avatar
Car: 91 Trans Am
Id have the shaft swapped at a trans shop vs find a replacement trans
Old Jun 3, 2010 | 09:43 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
^^^ This.
Look on the bright side, at least you're not sitting in the car the day of your first start-up and the thing won't turn over...been there, done that.
Old Jun 4, 2010 | 03:14 PM
Shift06's Avatar
Hey, there is still time for that too happen lol.
Old Jun 4, 2010 | 06:00 PM
silent420wolf's Avatar
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
i have the same setup for my tranny can u post pick of how you have the shifter cable attached to your 4l60e from the GTO
Old Jun 4, 2010 | 06:18 PM
Pocket's Avatar
Car: 91 Trans Am
3rd gen cable and bracket, moved one bolt forward from the stock 4L60E position. Its the only way it can reach, and moved up the reach is perfect
Old Jun 4, 2010 | 08:52 PM
RockJay81's Avatar
Old Jun 6, 2010 | 02:49 PM
kevinc's Avatar
Car: 1982 Z28
Post pics!
86IROC112
Apr 9, 2016 10:20 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
The_Phoenix
Feb 4, 2016 07:10 AM
The_Phoenix
Sep 3, 2015 10:56 PM
jharrison5
Aug 19, 2015 05:53 PM
