Injectors dont pulse whats the issue
Old Jul 3, 2010 | 09:41 PM
sszcam's Avatar
Car: 00 ss 89 iroc lt1
Engine: ls1, lt1
Transmission: M6, auto
I am wrapping up my Lt1 install and cannot get the car to run. I know I have fuel to the rails and have spark. THe car will fire off if carb cleaner is sprayed in the tb.
My question is what sensors or other things control the injectors?
THe harness that I used is a standalone unit so I didnt have to splice many wires and none specifically for the injectors.
Old Jul 3, 2010 | 10:27 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Injectors dont pulse whats the issue
Gotta have power to the injectors, or they won't work right.
Old Jul 4, 2010 | 06:12 PM
sszcam's Avatar
Engine: ls1, lt1
If the harness is getting power to supply spark and fuel why wouldnt it be getting power to the injectors?
Where do I start what do I need to rule out.
Old Jul 4, 2010 | 07:41 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
injectors run seperate +12v from the ignition and pump..
theres +12v from the pink/black wires usually (pink to 7.5A for LT1 per bank, looked it up) and then the ECM does the grounding.
VATs can disable it too
Old Jul 4, 2010 | 10:25 PM
Klortho's Avatar
Car: 1987 GTA
VATS doesn't disable the injectors on an LT1, it only keeps the fuel pump from running.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
