91' Z28 Vert LS3/T56
Old Jul 9, 2010 | 05:57 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
I have a 91' Z28 vert (originally TPI 305/Auto) with a built LS3 out of an 08' vette and T56 from Tick Performance. I installed the LS3 this past weekend after prepping the engine bay (new paint, Hawks heater box, new steering linkage, bushings, etc...). The K-member and control arms were chemically stripped and finished with eastwood chassis paint. The underbody was stripped and covered with eastwood rust encapsalator (highly recommend over POR-15). The Moroso LS pan fits great (just need to plumb remote filter). I have a Monster stage 3.5 clutch kit installed but still need to acquire the hydraulics and pedals. As far as wiring, I have a stand alone Mefi 4 system built by CBM motorsports. Looks like a quality piece with OEM connectors. This is a speed density system which runs on MSD's InGenius software.
Although I think I should have almost everything covered, I am sure I will have some questions along the way. As far as wiring, are there any circuits I should retain to keep gauges functional? I am assuming I need to keep basic power distribution, but can forego just about everything else? Perhaps may need some insight from Pocket...
Also, regarding the EVAP.... I will be reusing the stock 3rd gen gas tank and fuel lines, but want to keep the charcoal canister functional. How can I keep this functional? I believe this is controlled by the ECM?
Lastly... The Hawks T56 crossmember I have may be any issue. I like the idea for exhaust clearance, but there isn't a provision to run a torque arm. Anyone have insight on this?
I think that's it for now.
I bet it will be at least a year before it is on the road. There are plans for a new rear end, SFC's, custom dual exhaust to tie into the Hawks headers, C6 brakes, wheels/tires, and new top. Not to mention all the little stuff (plumbing, radiator, etc...).
Here is a picture of the engine installed and a few old pictures when I bought the car.
Attached Thumbnails 91' Z28 Vert LS3/T56-dscn0340.jpg   91' Z28 Vert LS3/T56-grass-top-up.jpg   91' Z28 Vert LS3/T56-91-z28-int..jpg
Old Jul 9, 2010 | 06:10 PM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Re: 91' Z28 Vert LS3/T56
Great job! is always good to see this cars get their lifes extended and yours looks mint in the pictures, very nice man enjoy!
Old Jul 9, 2010 | 06:33 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Nice vert I would ask pocket your wiring questions. I have seen some people here weld a torque arm mount onto the hawks cross member.
Old Jul 9, 2010 | 07:35 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Thanks BlueZee, I like your vert too! I'm sure I may have some questions for you as well along the way...
Old Jul 9, 2010 | 10:48 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
That thing is gonna be a beast!
Old Jul 29, 2010 | 07:02 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Bump.... Does anyone know how the charcoal canister is controlled? Does the ECM need to see some type of pressure in order to open to the intake? I just want to make sure this is still functional in my build.
Old Jul 29, 2010 | 07:13 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Man that's a sexy ride!
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
blackz281le
Jan 11, 2016 07:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
skip91
Sep 22, 2015 10:25 AM
