LT1 swap with p/s problem
Old Aug 28, 2010 | 12:40 PM
85streetmachine's Avatar
Car: 1985 iroc z
Engine: 6.0L coming
Transmission: 4L80E coming
Axle/Gears: 10 bolt 3.73
I recently swapped in a LT1, and put in a Summit Racing aluminum p/s reservoir. The problem im having is the p/s fluid is always coming out the top of the reservoir. The reservoir is baffled on the low pressure line, the system is not overfilled as the fluid constantly comes out until it runs dry. Ive bleed the air from the system already but it continues to happen. Anyone have any good suggestion????
Old Aug 28, 2010 | 03:01 PM
lee927's Avatar
Car: 90 rs
Re: LT1 swap with p/s problem
is it mounted higher than the pump? I'm not sure if that would be the issue. hose diameter to small maybe?
Old Aug 29, 2010 | 07:26 AM
Car: 1985 iroc z
Engine: 6.0L coming
The reservoir is mounted above the pump on the passenger fender, and ive got 5/8 id hose from the reservoir to the pump and 3/8 id line from the pump to the steering box and 3/8 line frox steering box back to the reservoir. Could the pump not be working properly or sucking the p/s fluid from the reservoir properly?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
